Haas Parameter 238 SPINDLE AT SPEED % – Haas Lathe
Allows program to command spindle to certain speed and then continue to next block before spindle has actually reached that speed. This is intended to make G-code programs run faster because the spindle can usually finish accelerating while approaching the part. It is recommended that this parameter be set to 20. The result will be that the lathe will act as though the spindle is at speed when it is within +/-20% of the commanded speed.
