Haas Parameter 57 COMMON SWITCH 1
Parameter 57 is a collection of general purpose single bit flags used to turn some functions on and off. Left and right cursor arrows select the function being changed. All values are 0 or 1 only. The function names are:
  • 0 REVERSE CRANK DIR – Reverses direction of jog handle.
  • 1 DISABLE TOOL CHANGER – Disables tool changer operations.
  • 2 DISABLE GEARBOX – Disables gearbox functions.
  • 3 POWER OFF AT E-STOP – Stops spindle, then turns the power off at Emergency Stop.
  • 4 RIGID TAPPING – Indicates hardware option for rigid tap.
  • 5 REV SPINDLE ENCODER – Reverses sense direction of spindle encoder.
  • 6 UNUSED .
  • 7 EXACT STOP MODE CHG – Selects exact stop in moves when mode changes.
  • 8 UNUSEDUNUSED.
  • 9 SPINDLE DRV LIN ACCEL – Selects linear deceleration for rigid tapping. 0 is quadratic.
  • 10 UNUSED
  • 11 COOLANT SPIGOT – Enables coolant spigot control and display.
  • 12 OVER TEMP IS N/C – Selects Regen over temp sensor as NC.
  • 13 UNUSED .
  • 14 NONINV SPINDLE STOP – Non-inverted spindle stopped status.
  • 15 SPIND. LOAD MONITOR – Spindle load monitor option is enabled.
  • 16 SPIND. TEMP MONITOR – Spindle temperature monitor option is enabled.
  • 17 ENABLE ROT & SCALNG – Enables rotation and scaling.
  • 18 ENABLE DNC – Enables DNC selection from MDI.
  • 19 UNUSED .
  • 20 ENABLE GROUND FAULT – Enables ground fault detector.
  • 21 M19 SPINDLE ORIENT. – Makes the P and R codes a protected feature, only enabled with an unlock code. The unlock code is printed on the parameter listing. If this bit is set to 0, an M19 will orient the spindle to 0 degrees, regardless of the value of any P or R code in the same block. If it is set to 1, a P code in the block will cause the spindle to be oriented to the specified angle; such as P180. Alternately, a decimal R code can be used, such as R180.53. Note that the P and R codes only work on a vector drive machine.
  • 22 ENABLE MACRO – Enables macro functions.
  • 23 INVERT SKIP – Invert sense of skip to active low = closed.
  • 24 HANDLE CURSOR – Enable use of jog handle to move cursor.
  • 25 NEGATIVE WRK OFFSET – Selects use of work offsets in negative direction.
  • 26 TRANS OIL LOW PRESS – Enables transmission low oil pressure detection.
  • 27 QUICK CODE – Enables conversational programming.
  • 28 OILER ON/OFF – Enables oiler power when servos or spindle is in motion.
  • 29 INV BUSS PWR FAULT – Inverts sense of over voltage signal. It must be set to zero on machines with a standard vector drive, and 1 on machines with a Smart Vector Drive or Mini Power Supply.
  • 30 SPINDLE ENCODER #2 – Enables a second encoder that is mounted on the spindle motor and wired into the C-axis input of the MOCON. It controls the vector algorithm on a belted machine when the belts slip at high load. When two encoders are present, the first is mounted on the spindle or output of the transmission, and is wired to the “spindle” input on the MOCON. Most mills use a single encoder that is mounted on either the spindle (transmission output) or spindle motor, but always connected to the spindle input on the MOCON.
  • 31 UNUSED– UNUSED
