Haas Parameter 612 SPIGOT TYPE – Haas Mill
Supports programmable coolant spigot. Type 0 uses peaks of the spigot fan for positioning. Type 1 uses the peaks and valleys of the spigot fan for positioning. All other values are treated the same as type 0. Note that if Parameter 253, Spigot Fwd Pos Dly and Parameter 304, Spigot Rev Pos Dly are non-zero, type 1 processing uses those values; otherwise, the type 1 processing calculates the delay value for positioning from Parameters 613 and 614.
