Haas Parameter 799 SHOWER COOLANT RLY – Haas Mill
Specifies output relay for shower coolant pump. When installed, it should be set to 32, otherwise it should be zero.
Parameters 801, 802 and 803 are for Haas Air Closer: The pneumatically controlled air closer uses these 3 parameters and (248, 800) to govern the operation of the system. The parameters are set as follows:
