Haas Parameter 814 AXIS PRESSURE TIMEOUT
Specifies the duration in milliseconds after the start of the axis lubrication cycle, during which high pressure is expected to occur. If pressure is not detected during this time, the control will display the LOW LUBE message. This parameter is inactive when parameter 813 is “0”. This parameter is activated depending on the value of parameter 810.
