Haas Parameter 9 X MAX ERROR
Maximum error allowed in servo loop before alarm is generated. Units are encoder steps. This is the maximum allowable error in Hz between commanded speed and actual speed. The purpose of this parameter is to prevent “motor runaway” in case of phasing reversal or bad parameters. If this parameter is set to 0, it defaults to 1/4 of Parameter 183, Max Frequency.
