Haas Setting 107 TS Hold Point – Haas Lathe
Haas Setting Description
This setting is in absolute machine coordinates and should be a negative value. It is the point to advance to for holding when M21 is commanded. Usually this is inside of a part being held. It is determined by jogging to the part and adding some amount to the absolute position.
