Haas Setting 121 Foot Pedal TS Alarm – Haas Lathe
Haas Setting Description
When M21 is used to move the tail stock to the hold point and hold a part, the control will generate an alarm if a part is not found and the hold point is reached. Setting 121 can be switched to On and an alarm will be generated when the foot pedal is used to move the tail stock to the hold point and no part is found.
