Haas Setting 130 Tap Retract Speed
Haas Setting Description
This setting affects the retract speed during a tapping cycle. Entering a value, such as 2, will command the mill to retract the tap twice as fast as it went in. If the value is 3, it will retract three times as fast. A value of 0 or 1 will have no affect on the retract speed. (Range 0-4)
Entering a value of 2, is the equivalent of using a J code of 2 for G84 (Tapping canned cycle). However, specifying a J code for a rigid tap will override setting 130.
Note: If the machine does not have the Rigid Tap option, this setting has no effect.
