Haas Setting 132 Jog or Home Before TC – Haas Lathe
Haas Setting Description
When this setting is Off, the machine behaves normally. When it is On and Turret Fwd, Turret Rev, or Next Tool is pressed while one or more axes is away from zero, it is assumed that a crash is likely and a message is displayed instead of doing the tool change. However, if the operator had pressed Handle Jog prior to the tool change, it is assumed that the axis had just been jogged to a safe position and will perform the tool change.
