Haas Setting 142 Offset CHNG Tolerance
Haas Setting Description
This setting generates a warning message if an offset is changed by more than the amount entered for this setting. The following prompt will be displayed: “XX changes the offset by more than Setting 142! Accept (Y/N)?” if an attempt is made to change an offset by more than the entered amount (either positive or negative), If “Y” is entered, the control updates the offset as usual; otherwise, the change is rejected.
If “Y” is entered, the control updates the offset as usual, otherwise, the change is rejected.
