Haas Setting 157 Offset Format Type
Haas Setting Description
This setting controls the format in which offsets are saved with programs.
When it is set to A the format looks like what is displayed on the control, and contains decimal points and column headings. Offsets saved in this format can be more easily edited on a PC and later reloaded into the control.
When it is set to B, each offset is saved on a separate line with an N value and a V value.
