Haas Setting 162 Default to Float
Haas Setting Description
When this setting is ON, the control will add a decimal point to values entered without a decimal point (for certain address codes). When this setting is Off, the values following the address codes are treated as machinist’s notation (i.e., thousandths or ten-thousandths.) For example:
Value entered | With Setting OFF | With Setting ON | |
In Inch mode | X-2 | X-.0002 | X-2. |
In MM mode | X-2 | X-.002 | X-2. |
This feature applies to the following address codes:
X,Y,Z,A,B,C,E,F,I,K,U,W
D (except with G73)
R (except with G71 in YASNAC mode)
Note that this setting affects the interpretation of all programs entered either manually or from disk or via RS-232. It does not alter the effect of setting 77 Scale Integer F.
