Haas Setting 164 Power up SP Max RPM – Haas Lathe
Haas Setting Description
This setting is used to clamp the spindle speed each time the machine is powered on. It causes a G50 Snnn command to be executed at power on time, where nnn is the value from Setting 164. If nnn contains zero, or a value equal to or greater than parameter 131 MAX SPINDLE RPM, Setting 164 has no effect.
