Haas Setting 164 Rotary Increment
Haas Setting Description
This setting applies to the Rotary Index button on the EC300. It specifies the rotation for the rotary table in the load
station. It should be set to a value from -360 to 360 degrees. For example, entering “90” will rotate the pallet 90°
each time the rotary index button is pressed. If it is set to zero, the rotary table will not rotate.
