Haas Setting 167-186 Periodic Maintenance
Haas Setting Description
There are 14 items that can be monitored, as well as six spare items, in the periodic maintenance settings. These settings will allow the user to change the default number of hours for each item when it is initialized during use. If the number of hours is set to zero, the item will not appear in the list of items shown in the maintenance page of current commands.
167 Coolant Replacement default in power-on hours
168 Control Air Filter Replacement default in power-on hours
169 Oil Filter Replacement default in power-on hours
170 Gearbox Oil Replacement default in power-on hours
171 Coolant Tank Level Check default in power-on hours
172 Way Lube Level Check default in motion-time hours
173 Gearbox Oil Level Check default in power-on hours
174 Seals/Wipers Inspection default in motion-time hours
175 Air Supply Filter Check default in power-on hours
176 Hydraulic Oil Level Check default in power-on hours
177 Hydraulic Filter Replacement default in motion-time hours
178 Grease Fittings default in motion-time hours
179 Grease Chuck default in motion-time hours
180 Grease Tool Changer Cams default in tool-changes
181 Spare Maintenance Setting #1 default in power-on hours
182 Spare Maintenance Setting #2 default in power-on hours
183 Spare Maintenance Setting #3 default in motion-time hours
184 Spare Maintenance Setting #4 default in motion-time hours
185 Spare Maintenance Setting #5 default in tool-changes
186 Spare Maintenance Setting #6 default in tool-changes
