Haas Setting 188/189/190 – G51 X/Y/Z SCALE
Haas Setting Description
The axes can be scaled individually using the following new settings (must be a positive number).
Setting 188 = G51 X SCALE
Setting 189 = G51 Y SCALE
Setting 190 = G51 Z SCALE
However, if setting 71 has a value, then settings 188-190 are ignored, and the value in setting 71 is used for scaling. If the value for setting 71 is zero, then settings 188-190 are used. Note that when settings 188-190 are in effect only linear interpolation, G01, is allowed. If G02 or G03 is used, alarm 467 will be generated.
