Haas Setting 191 Default Smoothness – Haas Mill
Haas Setting Description
This setting may be set to ROUGH, MEDIUM, or FINISH and uses parameters 302, 303, 314, 749, and 750-754 and G187 to set the smoothness and a maximum corner rounding factor.The default values are used when not overridden by a G187 command.
Haas Parameters
