Haas Setting 238 High Intensity Light Timer (minutes)
Haas Setting Description
Specifies the duration in minutes that the High Intensity Light option (HIL) remains turned on. It can be turned on if the door is opened and the work light switch is on. If this value is zero, then the light will remain turned on while the doors are open.
