Haas Setting 28 Can Cycle Act w/o X/Y
Haas Setting Description
Turning this setting “ON” will cause the commanded canned cycle to complete without an X or Y command. The preferred method of operation is with this setting ON.
When this setting is OFF, the control will stop if a canned cycle is programmed without an X or Y axis move.
