Haas Setting 36 Program Restart
Haas Setting Description
When this setting is On, restarting a program from a point other than the beginning will direct the control to scan the entire program to ensure that the tools, offsets, G and M codes, and axis positions are set correctly before the program starts at the block where the cursor is positioned.
The following M codes will be processed when Setting 36 is enabled:
M08 Coolant On | M37 Parts Catcher Off |
M09 Coolant Off | M41 Low Gear |
M14 Clmp Main Spndl | M42 High Gear |
M15 Unclmp Main Spndl | M51-58 Set User M Code |
M36 Parts Catcher On | M61-68 Clear User M Code |
When it is Off the program will start without checking the conditions of the machine. Having this setting Off may save time when running a proven program.
