Haas Setting 36 Program Restart – Haas Mill
Haas Setting Description
When this setting is ONN, restarting a program from a point other than the beginning will direct the control to scan the entire program to ensure that the tools, offsets, G and M codes, and axis positions are set correctly before the program starts at the block where the cursor is positioned.
Note: The following M codes will be processed when Setting 36 is enabled:
M08 Coolant OnM41 Low Gear Override
M09 Coolant OffM42 High Gear Override
M10 Engage 4th Axis BrakeM51-M58 Set Optional M Code
M11 Release 4th Axis BrakeM61-M68 Clear Optional M Code
M12 Engage 5th Axis BrakeM83 Air Gun On
M13 Release 5th Axis BrakeM84 Air Gun Off
M34 Increment Coolant Spigot PositionM88 Thru-Spindle Coolant ON
M35 Decrement Coolant Spigot PositionM89 Thru-Spindle Coolant OFF
When it is Off the program will start without checking the conditions of the machine. Having this setting Off may save time when running a proven program.
