Haas Setting 50 Aux Axis Sync
Haas Setting Description
This changes the synchronization between sender and receiver for the second serial port. The second serial port is used for auxiliary axes. The settings between the CNC control and the auxiliary axes must be the same.
Selecting “RTS/CTS” will tell the sender to temporarily stop sending data while the receiver catches up.
Selecting “XON/XOFF” uses ASCII character codes from the receiver to tell the sender to temporarily stop. XON/XOFF is the most common setting.
The “DC CODES” selection is like XON/XOFF, with the exception that start/stop codes are sent.
The “XMODEM” selection is receiver-driven, which sends data in blocks of 128 bytes. XMODEM gives the RS-232 communication added reliability because each block is checked for integrity.
