Haas Setting 69 DPRNT Leading Spaces
Haas Setting Description
This is an On/Off setting. When set to OFF the control will not use leading spaces generated by a macro DPRNT format statement. Conversely when set to ON the control will use leading spaces The following example illustrates control behavior when this setting is OFF or ON.
#1= 3.0;OUTPUT
0 G90 X#1;OFFON
PRNT[X#1[44]];X3.0000X 3.0000
Notice the space between the “X” and the 3 when the setting is ON. Information can be easier to read when this setting is ON.
