Haas Setting 72 Can Cycle Cut Depth – Haas Lathe
Haas Setting Description
Used with canned cycles G71 and G72, this setting specifies the incremental depth for each pass during rough cutting. It is used if the programmer does not specify a D code. Valid values range from 0 to 29.9999 inches or 299.999 mm. The default value is .1000 inches.
