Haas Setting 73 Can Cycle Retraction
Haas Setting Description
Used with canned cycles G71 and G72, this setting specifies the retraction amount after a roughing cut. It represents the tool to material clearance as the tool returns for another pass. Valid values range from 0 to 29.9999 inches or 299.999 mm.The default value is .0500 inches.
