Haas Setting 77 Scale Integer F
Haas Setting Description
This setting allows the operator to select how the control interprets an F value (feedrate) that does not contain a decimal point.(It is recommended that programmers always use a decimal point.) This setting helps operators run programs developed on a control other than HAAS. For Example F12:
Setting 77 OFF 0.0012units/minute
Setting 77 ON 12.0 units/minute
