Haas Setting 78 5th axis Enable
Haas Setting Description
When this setting is OFF, the fifth axis is disabled and no commands can be sent to that axis. In order to change this setting the Emergency Stop button must be pressed. See setting 30 for 4th axis. Note that there are two selections “USER1” and “USER2” that can be used to set-up a unique rotary table.
