Haas Setting 81 Tool At Power Up
Haas Setting Description
When the Power Up/Restart key is pressed, the control will change to the tool specified in this setting. If zero (0) is specified, no tool change occurs at power up. The default setting is 1.
Setting 81, will cause one of the following actions to occur during a Power-up/Restart:
A. If Setting 81 is set to zero, the carousel will be rotated to pocket #1. No tool change will be performed.
B. If Setting 81 contains the tool number of the tool currently in the spindle, the carousel will remain at the same pocket and no tool change will be performed.
C. If Setting 81 contains the tool number of a tool not currently in the spindle, the carousel will be rotated to pocket #1 and then to the pocket containing the tool specified by Setting 81. A tool change will be performed to change the specified tool into the spindle.
