Haas Setting 85 Max Corner Rounding
Haas Setting Description
This setting defines the machining accuracy of rounded corners within a selected tolerance. The initial default value is 0.025 inch (except on VF-5 trunion). If this setting is zero (0), the control acts as if an exact stop is commanded in each motion block.
G187 can be used in the program to alter the effective value of Setting 85, without changing the setting.
