Haas Setting 93 Tailstock X Clearance – Haas Lathe
Haas Setting Description
This setting works with Setting 94 to define a tail stock travel restriction zone that limits interaction between the tail stock and the tool turret. This setting determines the X-axis travel limit when the difference between the Z-axis location and the tail stock location falls below the value in Setting 94. If this condition occurs and a program is running then an alarm is generated. When jogging, no alarm is generated, but travel will be limited. Units are in inches.
