Haas Setting 95 Thread Chamfer Size
Haas Setting Description
This setting is used in G76 and G92 threading cycles when an M23 is commanded. When command M23 is active, threading strokes end with an angled retraction, as opposed to pulling straight out. The value in Setting 95 is equal to the number of turns (chamfered threads) desired. Note that Settings 95 and 96 interact with each other. Valid range: 0 to 29.999 (Multiple of current thread lead, F or E).
