Haas Setting 99 Thread Minimum Cut – Haas Lathe
Haas Setting Description
Used in G76 canned threading cycle, this setting sets a minimum amount of successive passes of the thread cut. Succeeding passes cannot be less than the value in this setting. Values can range from 0 through .9999 inch. The default value is .0010 inches.
