Hurco Mill G-code list for CNC machinists who work on Hurco CNC mill machines.
Hurco CNC are Advanced CNC machine tools including machining centers, turning centers, and 5-axis all with the WinMax cnc control.
Hurco VMX30U 5 axis machining centre
Download Hurco Manuals
Hurco programming manuals are free to download from Hurco website
Hurco CNC Manuals Programming and Maintenance Free Download.
Download Hurco WinMax Software
CNC machinists can download Hurco WinMax software free from Hurco website
Hurco CNC Software WinMax Free Download.
Hurco Mill G-Code List
-------------------------------------------------- G-Code Modal Function -------------------------------------------------- G00 M Positioning (Rapid Traverse) G01 M Linear Interpolation (Cutting Feed) G02 M Circular Interpolation/Helical CW G02.4 M 3D Circular Interpolation CW G03 M Circular Interpolation/Helical CCW G03.4 M 3D Circular Interpolation CCW G04 Dwell, Exact Stop G05.1 M Surface Finish Parameters G05.2 M Data Smoothing G05.3 M Surface Finish Quality G07.2 M Cylindrical Rotary Wrap On G07.3 M Cylindrical Rotary Wrap Off G08.1 M ASR Command Buffer On G08.2 M ASR Command Buffer Off G09 Decelerate Axis to Zero G10 Data Setting G11 Data Setting Mode Cancel G15 M Polar Coordinates Cancel G16 M Polar Coordinates G17 M XY Plane Selection G18 M ZX Plane Selection G19 M YZ Plane Selection G20 M Input in Inch (ISNC) G21 M Input in mm (ISNC) G28 Return to Reference Point G29 Return from Reference Point G31 Skip G40 M Cutter Compensation Cancel G41 M Cutter Compensation Left G41.2 M 3D Tool Geometry Compensation G42 M Cutter Compensation Right G43 M Tool Length Compensation + Direction G43.4 M 5-Axis Linear Interpolation G44 M Tool Length Compensation - Direction G45 Tool Offset Increase G46 Tool Offset Decrease G47 Tool Offset Double Increase G48 Tool Offset Double Decrease G49 M Tool Length Offset Compensation Cancel G50 M Scaling Cancel G51 M Scaling G50.1 M Mirroring Cancel G51.1 M Mirroring G52 Local Coordinate System Setting G53 Machine Coordinate System Selection G54 M Work Coordinate System 1 Selection G54.1 M Aux Work Coordinate Systems G55 M Work Coordinate System 2 Selection G56 M Work Coordinate System 3 Selection G57 M Work Coordinate System 4 Selection G58 M Work Coordinate System 5 Selection G59 M Work Coordinate System 6 Selection G61 M Decelerates to Zero–Precision Cornering G64 M Cancels Precision Cornering G65 Macro Command, Subprogram Call G66 M Modal Subprogram Call G67 M Modal Subprogram Call Cancel G68 M Coordinate Rotation G68.2 M Global Rotation NC Transform Plane G68.3 M Local Rotation NC Transform Plane G69 M Coordinate System Rotation Cancel G70 M Input in Inch (BNC) G71 M Input in mm (BNC) G73 M Peck Drilling Cycle G74 M Left-handed Tapping Cycle(ISNC) G74 M With M29 Rigid Tapping (ISNC) G74 M Single-quadrant Circular Interpolation (BNC) G75 M Multi-quadrant Circular Interpolation (BNC) G76 M Bore Orient Cycle G80 M Canned Cycle Cancel G81 M Drilling Cycle, Spot Boring G82 M Drilling Cycle, Counter Boring G83 M Peck Drilling Cycle G84 M Tapping Cycle G84.2 M Rigid Tapping Cycle (ISNC) G84.3 M Rigid Tapping Cycle (ISNC) G84 M With M29 Rigid Tapping Cycle (ISNC) G85 M Boring Cycle G86 M Bore Orient Cycle (BNC) G86 M Bore Rapid Out Cycle (ISNC) G87 M Chip Breaker Cycle (BNC) G87 M Back Boring Cycle (ISNC) G88 M Rigid Tapping Cycle (BNC) G88 M Boring Cycle Manual Feed Out, Dwell (ISNC) G89 M Boring Cycle Bore and Dwell G90 M Absolute Command G91 M Incremental Command G92 Programming of Absolute Zero Point G93 M Inverse Time G94 M Feed per Minute G94.1 M Rotary Tangential Velocity Control G98 M Return to Initial Point in Canned Cycle G99 M Return to R Point in Canned Cycle
