Hust CNC G code list for cnc machinists who work on CNC Mill with Hust CNC controls.
Following G code works on,
Hust CNC H4M, Hust cnc H4CL-M and related Hust cnc mill controls.
Hust CNC G Code List – CNC Mill
G-code Function
G00 Rapid positioning (fast feed-rate)
G01 Linear cutting (cutting feed-rate)
G02 Arc cutting, CW (cutter at rear)
G03 Arc cutting, CCW (cutter at rear)
G04 Dwell command, Temporary stop
G08 Clear machine coordinates in all axis
G10 Data input
G20 System measurement in INCH mode
G21 System measurement in METRIC mode
G22 Linear grooving
G23 Arc grooving
G24 Rectangular grooving
G25 Circular grooving
G28 Tool moves to the 1st reference point
G29 Moves back to the specified position from the ref. point
G30 Tool moves to the 2nd reference point (10 groups in total)
G31 Skip function
G34 Circular drilling canned cycle
G35 Angular drill canned cycle
G36 Arc drill canned cycle
G37 Grid drill canned cycle
G40 Tool radius compensation – cancel
G41 Tool radius compensation – set (left)
G42 Tool radius compensation – set (right)
G43 Tool length compensation- positive direction
G44 Tool length compensation-negative direction
G49 Tool length compensation-cancel
G50 Proportion function cancel
G51 Proportion function setting
G54 The first work coordinate
G55 The second work coordinate
G56 The third work coordinate
G57 The fourth work coordinate
G58 The fifth work coordinate
G59 The sixth work coordinate
G68 X-axis mirror-effect cutting
G69 Y-axis mirror-effect cutting
G80 Drill canned cycle, cancel
G81 Drill canned cycle, set
G82 Drill canned cycle-temporary stop at bottom
G83 Deep hole drilling canned cycle
G84 Tap Cutting canned cycle, Steel threading
G85 Boring cycle
G86 Boring cycle-spindle stop at bottom
G89 Boring cycle-temporary stop at bottom
G90 Command for absolute coordinate
G91 Command for increment coordinate
G94 Feed-rate specified by mm/min
G95 Feed-rate specified by mm/revolution
