Mazak Alarm 327 NOT IN ATC START POSITION
Description
The condition to perform ATC is not appropriate. The details are described at the left. See D200/D201.
Check and remedy
90 (D201) The machine is under locking state. After releasing the machine lock, press the cycle start button. The ATC will be executed.
91 (D201) The tailstock is in the connection state. After releasing the connection of the tailstock, perform the ATC.
97 (D201) When the loading tool is specified in the ATC, the shifter is not placed at the ATC side. Move the shifter manually on the ATC side.
98 (D201) The magazine cannot be rotated because the specified tool is different from the loading tool and the shifter is not placed on the ATC side. Move the shifter to the ATC side manually.
99 (D201) The shifter is not placed in the magazine side without the loading tool when commanding the ATC. Move the shifter to the magazine side/retract position manually.
9800 (D200) The tool command is given incorrectly. Perform again.
9900 (D200) The ATC arm is not at the reference point position. Move the ATC arm to the reference point position manually. Then perform again the ATC.
