Mazak Alarm 381 CONDITION MISSING (SET UP SWITCH)
Description
The cycle start button has been pressed in automatic operation mode with the front door open and the setup key switch set to “O”.
Check and remedy
Change the setting of the setup key switch to “I” and then press the cycle start button. Single-block automatic operation will be activated.
Description
For a machine of the front door lock pin specifications, a manual-starting button has been pressed with the front door open and the setup key switch set to “O”.
Check and remedy
Change the setting of the setup key switch to “I” and then press the desired manualstarting button. The override rate will be reduced to 25%.
