Milltronics G Code for CNC machinists who work on CNC lathe machines with Milltronics CNC controls.
You might read G codes for Milltronics Centurion 7 CNC control Milltronics Centurion 7 G Code List
Milltronics CNC Control
Milltronics G Code for Lathes
G Code | Function |
G00 | Rapid Positioning |
G01 | Linear Interpolation |
G02 | Circular/Helical Interpolation CW |
G03 | Circular/Helical Interpolation CWW |
G04 | Dwell |
G09 | Exact Stop |
G10 | Set Data On |
G11 | Set Data Off |
G12 | Clear Floating Zero |
G13 | Back Side Programming |
G14 | Front Side Programming |
G20 | Inch Input |
G21 | Metric Input |
G22 | Safe Zone Check Off |
G23 | Safe Zone Check On |
G28-G30 | Reference Point Return |
G32 | Threading |
G34-G36 | Threading |
G38 | Initial Point Return |
G39 | R-Plane Return |
G40 | Cutter Compensation Cancel |
G41 | Cutter Compensation Left |
G42 | Cutter Compensation Right |
G45 | Z to Clearance |
G46 | X to Clearance |
G47 | Z to Tool Change |
G48 | X to Tool Change |
G49 | Cancel H Offset |
G50 | Set FLZ, Max RPM’s |
G52 | Local Coordinate System Set |
G53 | Machine Coordinate System |
G54 | Work Coordinate 1 System (G540…G549) |
G55-G59 | Work Coordinate 2-6 System (G5#0…5#9) |
G60 | One-Shot Rapid |
G61 | Exact Stop Mode |
G63 | Tapping Mode |
G64 | Cutting |
G65 | Non-movement |
G70 | Finish Cycle |
G71 | Rough Turning |
G72 | Rough Facing |
G73 | Pattern Repeat |
G74 | Face Grooving |
G75 | Diameter Grooving |
G76 | Threading Cycle |
G80 | Cancel Canned Cycle |
G81 | Drill |
G82 | Drill / Dwell |
G83 | Peck / Drill |
G84 | Tap |
G85 | Bore |
G86 | Bore / Spindle Stop |
G89 | Bore / Dwell |
G90 | Turning Cycle A |
G91 | Incremental Dimension |
G92 | Thread Cutting Cycle |
G93 | Absolute |
G94 | Facing Cycle B |
G96 | Constant Surface Speed |
G97 | Revs per Minute |
G98 | Feed per Minute |
G99 | Feed per Rev |
G501 | Mirror Image Off |
G511 | Mirror Image On |
G550 | Scaling Off |
G551 | Scaling On |
G568 | Rotation On |
G569 | Rotation off |
G990 | Store Parameters |
G991 | Read Parameters |
G995 | Read Byte Parameters |
G996 | Set Byte Parameters |
G997 | Force Error |
G998 | Beep |
G999 | Force Fatal Error |
