Complete Milltronics G Code List for CNC machinists who work on CNC Mill with Milltronics CNC control.
You might like
Milltronics G Codes for Machining Centers
Milltronics G Code List for Machining Centers
G Code | Function |
G00 | Rapid Positioning |
G01 | Linear Feed |
G02 | Circular / Helical Interpolation CW |
G03 | Circular / Helical Interpolation CCW |
G04 | Dwell |
G09 | Exact Stop |
G10 | Set Data On |
G11 | Set Data Off |
G12 | Clear Floating Zero |
G17 | XY Plane |
G18 | XZ or ZX Plane |
G19 | YZ Plane |
G20 | Inch Input |
G21 | Metric Input |
G22 | Safe Zone Check Off |
G23 | Safe Zone Check On |
G24 | Circular Pocket Clear |
G25 | Circular Finish Inside |
G26 | Circular Finish Outside |
G28-G30 | Reference Point Return |
G31 | Z to Clearance |
G32 | Z to Tool Change |
G33 | Facing Cycle |
G34 | Rectangular Pocket Clear |
G35 | Rectangular Finish Inside |
G36 | Rectangular Finish Outside |
G39 | Threading Mill Cycle |
G40 | Cutter Compensation Cancel |
G41 | Cutter Compensation Left |
G42 | Cutter Compensation Right |
G43 | H Offset Added |
G44 | H Offset Subtracted |
G45 | Auto Cutter Compensation Left |
G46 | Auto Cutter Compensation Right |
G47 | Auto Cutter Compensation Off |
G49 | H Offset Cancel |
G50 | Scaling Cancel |
G51 | Scaling Set |
G52 | Local Coordinate System Set |
G53 | Machine Coordinate System |
G54 | Work Coordinate 1 System (G540-G549) |
G55-G59 | Work Coordinate 2-6 System (G5#0-G5#9) |
G60 | Single Direction Rapid Positioning |
G61 | Exact Stop Mode |
G63 | Tapping Mode |
G64 | Tapping Mode Off |
G65 | Non-movement / Program Call |
G68 | Set Rotation |
G69 | Rotation Cancel |
G70 | Mirror Cancel |
G71 | Mirror Set |
G72 | Bolt Hole Routine |
G73 | Woodpecker |
G74 | Left-hand Tapping |
G75 | Counter Bore |
G76 | Fine Bore |
G77 | Custom Drill Cycle |
G78 | Manual Bore |
G79 | Custom Drill Cycle |
G80 | Cancel Canned Cycle |
G81 | Drill |
G82 | Drill / Dwell |
G83 | Peck / Drill |
G84 | Right-hand Tapping |
G85 | Bore |
G86 | Fast Bore |
G87 | Back Bore |
G88 | Hard Tap |
G89 | Bore / Dwell |
G90 | Absolute Dimension |
G91 | Incremental Dimension |
G92 | Work Coordinate Chg. (Set Fl. Zero) |
G93 | Inverse Time Feed Mode |
G94 | Feed Per Minute |
G95 | Feed Per Revolution |
G98 | Canned Cycle Initial Level Return |
G99 | Canned Cycle R Point Level Return |
G187 | Rough Cutting |
G188 | Medium Cutting |
G189 | Finish Cutting |
G271 | Pocket Clear |
G666 | Polygon Circle |
G990 | Store Parameters |
G991 | Read Parameters |
G995 | Read Byte Parameters |
G996 | Set Byte Parameters |
G997 | Force Error |
G998 | Beep |
