Okuma Alarm-A 1262 W-axis plus variable limit over
Tow-along tailstock exceeds the W-axis plus variable limit.
AXIS, SYSTEM
1->During operation using programmed commands
2->During automatic returning to the joint point in manual operation intervention mode
W-axis limit has been set so that the tow-along tailstock joint position will be outside the soft-limit position.
Shift the W-axis limit position outside if possible.
If such setting is not allowed, operate the turret manually and carefully to connect the tailstock so that interference will not occur.
Related Specifications
Programmable tailstock
