Okuma Alarm-A 1263 W-axis minus variable limit over
Tow-along tailstock exceeds the W-axis minus variable limit.
AXIS, SYSTEM
1->During operation using programmed command
2->During automatic returning to the joint point in manual operation intervention mode
W-axis limit has been set so that the tow-along tailstock point position will be outside the soft-limit position.
Shift the W-axis limit position outside if possible.
If such setting is not allowed, operate the turret manually and carefully to connect the tailstock so that interference will not occur.
Related Specification:Programmable tailstock
