Okuma Alarm-A 1306 Sensor touch G00
The sensor has been brought into contact with the workpiece during G00 mode feed while the execution of the G30 work gauging cycle.
In the work gauging cycle, the touch sensor is fed in the G00 mode between the gauging cycle start point and the approach point.
The touch sensor contacts the workpiece surface during this feed mode.
Program error
Check the target point for the work gauging cycle. (Check whether the programmed target point and the actual workpiece position coincide each other.)
Related Specification:Gauging cycle specification
