Okuma Alarm-A 1339 Spindle different from position when door open
On the machine intended for CE marking, when the state of servo off by door-open returned to the state of servo onby door-close, the following conditions are not met.
1)In C-axis control, the position of Main spindle is at least 0.36 (equivalent to 0.5mm) away from the switch OFF position.
2)The spindle or M-tool spindle in the state of synchronized rotation, or flat turning is at least 0.36 (equivalent to 0.5mm) away
SYSTEM, M-TOOL SPINDLE
