Okuma Alarm-A 1347 STM time over
The STM operation time exceeded the parameter-set time.
[Parameter]
OPTIONAL PARAMETER (CYCLE TIME OVER CHECK)
STM time over timer (0.1s)
Parameter-set time in hexadecimal
1)The NC received no answer to the STM command being executed when this alarm occurred.
Program Example:
: M03 M42 S1000 T0303 :
1)Display the check screen to see if the input signal is sent in answer to the STM command executed on occurrence of the alarm. If two or more commands are given, give the commands one by one in MDI operation to find out which STM command causes the alarm.
2)If “0” is set at the OPTIONAL PARAMETER (CYCLE TIME OVER CHECK) Cycle/STM time over alarm level, the alarm B
2295 STM time over occurs instead of this alarm.
