Okuma Alarm-A 1348 Cycle time over
One cycle time (from start to M02 or M30) exceeded the parameter-set time.
[Parameter]
OPTIONAL PARAMETER (CYCLE TIME OVER CHECK)
Cycle time over timer (s)
1)The part program has a long machining time. Or, the part program failed to end because a programmed operation was not completed.
1)Review the machining time in the part program or check the machining operations.
2)if “0” is set at the OPTIONAL PARAMETER (CYCLE TIME OVER CHECK) Cycle/STM time over alarm level.
the alarm C 3206 Cycle time over occurs instead of this alarm.
