Okuma Alarm-A 1440 Steady rest-Tailstock interlock
1->A position command of programable tailstock is over than maximum distance of a steady rest and a tailstock.
2->A position command of programable tailstock is less than minimum distance of a steady rest and a tailstock.
3->The Steady rest movement command exceeded Maximum distance between the Steady rest and the Tailstock.
4->The Steady rest movement command exceeded Minimum distance between the Steady rest and the Tailstock.
5->It started moving to the position in which it interfered with Steady rest and Tailstock.
Program error
Please turn the instruction-position on a right value.
