Okuma Alarm-A 1472 Stroke end over XS-axis
The Xs-axis(cam-axis) reaches the travel end.
Index
1->Emergency limit in the positive direction
2->Emergency limit in the negative direction
The Xs-axis soft-limit is set outside the range defined by the travel limit to be detected by the limit switch.
1)Select the manual mode and reset the NC while pressing the Xs-axis emergency limit release button provide at the side of the operation panel to clear the alarm state.
2)Press the Xs-axis fog button while holding down the Xs-axis emergency limit release button.
The Xs-axis is automatically positioned inside the allowable travel range.
3)Set the soft-limits correctly.
