Okuma Alarm-A 1511 SPM contour control not possible
Super-NURBS control was attempted without satisfying the conditions for executing the control.
Index
XYY
X=1:NURBS interpolation processing and the other function generation processing were attempted at the same time.
YY:States of the other commands when NURBS interpolation processing was attempted
bit0->positioning command (G00) is specified at the time.
bit1->Linear interpolation (G01) is specified at the time.
bit2->Arc interpolation or helical cutting (G02/G03) is specified at the same time.
bit3->Dwell (G04) is specified at the same time.
bit4->Manual shift amount cancel is specified at the same time.
bit7->Tolerance control mode ON is specified at the same time.
[Cause]
NC control software design error
X=F:Return to the middle of NURBS block was attempted by the return search function.
YY=01->Option code MX was specified.
YY=02->Option code MY was specified.
YY=03->Option code MZ was specified.
YY=04->Option code TS was specified.
The above option codes for returning to the middle of NURBS block by return search cannot be used. Perform return search without specifying these option codes.
XYY=200:Teaching mode was detected under the control by Super-NURBS.
Turn off the teaching mode. Super-NURBS control is impossible during the teaching mode.
