Okuma Alarm-A 1512 SPM contour control error
The NC detected such a fatal error that it was impossible to continue processing by SPM engine.
(Super Precision Machining (SPM) control = Hi-Cut Pro or Super-NURBS)
2000100->B Buf. Abnormality of Super Control Interval Code
2000200->B Buf. Abnormality of G code
2001000->B Buf. Abnormality of Dryrun Function Flag
2001100->B Buf. Abnormality of Feedrate Override Function Flag
2001110->B Buf. Abnormality of Soft Feedrate Override Function Flag
2001120->B Buf. Abnormality of Feedrate Override Function Flag
2001200->B Buf. Abnormality of Spindle Override Function Flag
2001300->B Buf. Abnormality of Single Block Function Flag
2001400->B Buf. Abnormality of Slide Hold Function Flag
2002000->B Buf. Abnormality of F1 Feedrate Order Number
2002100->B Buf. Abnormality of NC Program Instructions Unit
2002300->B Buf. Abnormality of Data Block Sequence Number
2002400->B Buf. Abnormality of F1 Feedrate Override
2002500->B Buf. Abnormality of F code direct Feedrate
2002600->B Buf. Abnormality of S code direct Spindle Velocity
2002700->B Buf. Abnormality of Program Tolerance
2002800->B Buf. Abnormality of Machining Tolerance
2003200->B Buf. Abnormality of ARC:Vector(Start->Center)
2003210->B Buf. Abnormality of ARC:Vector(Center Axis)
2003220->B Buf. Abnormality of ARC:Vector(End->Center)
2003240->B Buf. Abnormality of ARC:Radius
2003300->B Buf. Abnormality of HELICAL:Vector(Start->Center)
2003310->B Buf. Abnormality of HELICAL:Vector(Center Axis)
2003320->B Buf. Abnormality of HELICAL:Vector(End->Center)
2003340->B Buf. Abnormality of HELICAL:Radius
2003400->B Buf. Abnormality of NURBS:Degree(Order-1)
2003420->B Buf. Abnormality of NURBS:Knot Sequence
3002300->C Buf. Abnormality of Data Block Sequence Number
4000000->E Process Can’t interpolate NURBS Data (0-differential).
4002300->D Buf Abnormality of Data Block Sequence Number
5000000->F Process Can’t interpolate NURBS Data (0-differential).
5002300->E Buf Abnormality of Data Block Sequence Number
5006000->Abnormal length of the block for process F data
6000600->F Buf Abnormality of Interpolation Data Sequence Number
F000000->T Process Abnormality of Control Parameter
10000000->TB Data Manager The abnormal (end of the beginning) detection on the continuous sequence
10000001->TB Data Procedure The G code violation in implementation block
10000002->TB Data Procedure The plane specification violation in implementation block (Unreasonable axis index)
10000004->T Ground Manager Data Transfer Replying Timeout
10000005->TH Data Manager Serial Number Irregular
Faulty software
