Okuma Alarm-A 1520 Synchronous error limit over
1.The synchronization error exceeds permissible limit B for 128 ms or longer upon the powerup.
2.The synchronization error exceeds permissible limit A for 128 ms or longer at any time other than power-up.
Permissible maximum synchronization error A: System parameter
Permissible maximum synchronization error B: System parameter
Axis
The synchronization error at the time of alarm as expressed by hexadecimal notation.
In the case of 1:
The master or slave axis fell down after the power-down or the brake has Failed
In the case of 2:
The master or slave axis was overloaded during operation or the servo has failed.
In the case of 1:
Correct using the pulse handle set to X1 in the synchronized error correction mode.
Then, exit the mode and press RESET.
In the case of 2:
Turn the power off and then on again.
related Specifications
ZA AXIS SYC. AXIS
XA AXIS SYC. AXIS
